It is currently Fri Aug 15, 2025 5:41 pm
PostPosted: Fri Nov 21, 2014 11:22 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
Hi Everyone.
I got a great deal on a delta 14" bandsaw in like new condition with 2 extra blades. ($150!)
I ordered a mobile locking base and an adapter sleeve so the 4" dust port will connect to my 2.5" shop vac hose.
I don't plan on resawing sides/backs yet so I don't think I need a riser at this point.
Should I get a fence for it? Anything else you would recommend?
PostPosted: Fri Nov 21, 2014 11:59 pm
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
Yes, I recommend getting a fence. I have one on my old Delta 14" and I use it all the time. It was one of those things that, once I had it, I knew I had waited too long to get!
It will probably be alright.
These users thanked the author Greg Maxwell for the post: ernie (Sat Nov 22, 2014 2:59 pm)
PostPosted: Sat Nov 22, 2014 12:25 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
I'd rate a fence as a necessity.
Pretty much any fence will do the job nicely - being a band saw, cutting precision thickness isn't really the game, so there's usually no need for fancy fencing. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post: Lonnie J Barber (Sun Nov 23, 2014 3:45 pm)
PostPosted: Sat Nov 22, 2014 12:47 am
First name: Patch
Last Name: Rubin
great score!
definitely get a fence. also its really worth it to get yourself a good book on how to set properly set up the saw.
this is a good one... http://www.amazon.com/Bandsaw-Book-Lonnie-Bird/dp/1561582891/ref=sr_1_1?s=books&ie=UTF8&qid=1416634820&sr=1-1&keywords=bandsaw
http://www.wideskyguitars.com
https://www.instagram.com/wide_sky_guitars/
PostPosted: Sat Nov 22, 2014 6:20 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I put a Kreg on mine. Works pretty well and has a drift adjustment.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Nov 22, 2014 8:56 am
Drift adjustment is necessary if you ask me. I have a cheap bandsaw and have to use a block of wood as a fence once I get the drift set right. Then it works great. Nice score BTW.
PostPosted: Sat Nov 22, 2014 9:06 am
First name: Linus
City: Brooklyn
Thanks for the replies! I'll place the order for a fence.
I watched a bunch of YouTube videos about how to set it up before I did anything with it. I'm glad I did.
I'll check out that book though. Thanks for the tip.
PostPosted: Sat Nov 22, 2014 9:16 am
First name: Patrick
Last Name: Hanna
State: Missouri
Linus, you can easily build all the fences you will ever need. You can build them from scraps of wood, MDF, etc. Make them the length of your table and you can clamp them fore and aft. Or build a short fence with a long perpendicular base and clamp the base at the side of your table. Build a taller fence for resawing. You don't need to spend a bunch of money on this.
JF McKenna is correct--you will probably need to adjust for blade drift from time to time. A clamped (rather than locked) fence is particularly good for that.
PostPosted: Sat Nov 22, 2014 9:45 am
I've got a Kreg on my Delta and I use it a lot.
PostPosted: Sat Nov 22, 2014 9:54 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I did the wood fence/clamps setup for years. Added the Kreg fence recently and life became a whole lot easier! Money very well spent.
PostPosted: Sat Nov 22, 2014 3:58 pm
Last Name: Beaver
City: Lake Forest
I put a Kreg on mine to. She's a dandy.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Nov 25, 2014 6:50 pm
I don't post often but feel like it when I have something worthwhile to post. I would recommend contacting Iturra Design at 904.642.2802 and asking for the Bandsaw Accessory Catalog. They do not have an online site, last I checked, but are very easy to work with. The catalog give a lot of setup hints, history of the 14 inch bandsaw and is highly directed to Delta, I have a Jet but they work for me. They have a lot of upgrade stuff: rollers, springs, levers, tires, and tools. Good Luck
Mike W
These users thanked the author gold660 for the post: Al Pepling (Mon Dec 01, 2014 6:40 pm)
PostPosted: Wed Nov 26, 2014 12:13 pm
First name: Linus
City: Brooklyn
Thanks gold660! I requested the catalog.
PostPosted: Wed Nov 26, 2014 8:05 pm
First name: EddieLee
Last Name: Brown
I too have a Kreg fence. Works good for me. I use it a lot.
_____________
EddieLee
PostPosted: Mon Dec 01, 2014 8:38 pm
First name: Dane
Last Name: Nichols
City: Mt. Shasta
State: Ca.
Zip/Postal Code: 96067
A fence is a must for resawing IMHO. As for drift once you get things lined up so you get a nice parallel cut you can scribe a line in the table for future reference. I lucked out on my saw it tracks great with the miter slot.
PostPosted: Tue Dec 02, 2014 10:37 am
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Zip/Postal Code: V0R 1K1
I put a Kreg on mine too. Love it!
Rick Hubka
Chemainus BC Canada
Users browsing this forum: doncaparker and 13 guests
